Is it possible to broadcast with vDJ to 2 decoders for a irc-stream radio . ( per example Broadband and Narrowband) And it is it possible to use a mic thru vDJ ?
geposted Tue 13 Sep 05 @ 8:30 am
Ardon,
VDJ only broadcast in one decoder, from 24Kbps to 320Kbps. You could get more broadcast thru a server. The server must be running 2 or more broadcast at different velocities.
It's possible use a mic thru VDJ.
geposted Tue 13 Sep 05 @ 5:59 pm
how can i use the mic thru vDJ ?
geposted Wed 14 Sep 05 @ 3:59 pm
You need VDJ 3.1 FULL, and connect to your mic input of your sound card; you're ready. The output signal is recorded by VDJ or broadcasta as well.
geposted Wed 14 Sep 05 @ 8:08 pm
Is it possible to Broadcast at all from the Trial version? I can't seem to find the Broadcast configuration options... I see a Network tab in Config that allows synchronization with "instances" but I assume that to be other instances of VDJ...
geposted Sat 11 Mar 06 @ 4:00 am
