Forum: Old versions
Topic: Song position can be different between VDJ and VTC
After launching a deck, if I change the position of the cartridge, the position of the song on VDJ does not correspond to VTC position.
And sometimes, when I reverse manually the vinyl, the song does not go back at the beginning: it can stop some beats after the beginning. I have to use stop key on skin of vdj to restart from the very beginning.
geposted Tue 13 Sep 05 @ 10:57 pm
It is because virtual dj adapt the 12min vinyl timecode to the length of the song everytime.
When you start the timecode and song from the beginning, they are in sync, a kind of "absolute" mode but when:
1. use (software's) cue points and loops
2. scratching hard and skipping
3. or manually change the needle position
the sync is lost and vdj turns into a "relative" mode
This is what i called "smart" mode, it is fine or normal mixing, but it produces many problems
under some circumstances.
Please read this post for more info (and support) :
https://virtualdj.com/forums/12661/New_features/Timecode_MODES___PLeaSe_________.html?highlight=relative%20mode
AND.....PLEASE.. (TEAM) add true Absolute and relative modes...
thax apopsis for your answer
I have discovered this problem trying to make pass-pass.
Another one problem : put the same song on the 2 decks of vdj, the output level is not the same on my tablemix....???
check volume in maya44 setup of each channel
Dj Nikki
