why is it gone in my vdj settings.
i wanna use tccd.
it won't work.
i wanna use tccd.
it won't work.
geposted Thu 15 Sep 05 @ 8:39 pm
you have to select timecode ASIO in soundcard, then after they are setup on the bottom of the timecode config screen you will see 33rpm 45 rpm or *cd* all TC's work the same way.
geposted Thu 15 Sep 05 @ 8:47 pm
I'm guessing there is no way to use the timecode CD with regular (non ASIO) audio input?
geposted Wed 28 Sep 05 @ 4:42 pm
@GiraffeHunter: you could use ASIO4ALL to use TCCDs with 2 regular soundcard. You need 2 stero inputs to get it working. This only could do with VDJ full version.
@ djjb: Remote 2 isn't available since VDJ 3.0. You have to use ASIO drivers or ASIO4ALL and 2 stereo inputs from one card or 2 cards.
geposted Wed 28 Sep 05 @ 7:21 pm
thnx.....i know what to do..
geposted Thu 29 Sep 05 @ 7:38 am
