i've created a plylist, and i want to play the song one after another.
simple enough.
but when the songloaded in the player' the player set the in and out point automaticly'
and the mix is like 20 seconds before the end of the song.
i would like to disable the in and out point so the mix will be like 6 seconds from the end.
is there any solution for that?
thanks
simple enough.
thanks
geposted Fri 16 Sep 05 @ 2:45 pm
Use "force fade" in the fame settings of VDJ with the option "fade length=0"
geposted Fri 16 Sep 05 @ 3:48 pm
did it, now thers no fade at all.
i want fade between the 6 sec. end of the first song end 6 sec start of the second song
thanks
thanks
geposted Fri 16 Sep 05 @ 5:52 pm
Hi, try changing fading time....1sec. will smooth the mix
geposted Sat 17 Sep 05 @ 3:54 am
Yes' but when i set to 1 sec it chooses the in and out point by himself.
i don't want any in and out point.
thanks
thanks
geposted Sat 17 Sep 05 @ 10:46 am
