Hi every body, how are you all ?!! hope you all are fine :)
I want from someone to help me in using Atomixmp3 program..
I want to know how to use the effects on the songs, and the samples in what can help me, the loop and so on .. etc.
I want a clear description about how to use the program and the basic things in it..
Plz reply me as soon as you can, and thank you ..
geposted Fri 16 Sep 05 @ 9:09 pm
No comments ??
No replays ??
No one will help me !!
No replays ??
geposted Sat 17 Sep 05 @ 9:03 am
Do you have a licenese emirate?, If you have a license enter it into your profile, and we will be glad to help you.
If you have an illegal copy then no your right, no one will help you..
geposted Sat 17 Sep 05 @ 6:35 pm
Hi,
Sorry what you mean by license ?!! license for what should i have ?? and from where i can get it ??
thank you for replaying me :)
geposted Sat 17 Sep 05 @ 9:51 pm
You can buy Atomix here: www.atomixmp3.com
Upon buying the software you'll be able to download the software and aquire a license, or your own serial number, If you have a serial number enter it into your profile (top left of the page - "modify my profile").
If you have not yet bought the software, what is it you'd like to know?.
geposted Sat 17 Sep 05 @ 11:38 pm
