just got vdj 3.1 and xp10s. i used them at my gig tonight for video and audio. the problem that i have is that when i have both of them hook up to the laptop and mixer (with audio outs on two separate channels), There is only output out of the one xp10 to one channel on the mixer. it forced me to crossfade on the program all night rather than being able to use two separate channels. does any one know how to configure the sound card part and the xp10s to work with an external mixer so each xp10 is on their own channel. Also, can you tell me on the mapping function how i can map a loop in, loop out, and loop exit like on the cdj800s. thanks for your help.
geposted Sun 18 Sep 05 @ 7:54 am
in VDJ's config panel, in the sound card tab, pick the 7th config down (with the pick of two sound cards going into a mixer. Then make sure Sound Card 1 and Sound Card 2 each list a different xp10 unit (they have the same name, but pick the first one in one and the second one in the other).
Then, check-out https://virtualdj.com/forums/7067/General_Discussion/another_xp10_question.html for details on invert/swap function (kind of complicated to understand).
enjoy!
enjoy!
geposted Sun 18 Sep 05 @ 10:24 am
