I think that's what it's called. When I have VDJ running, if I switch to anther program or minimize it, I get a glitch when the screen goes completely blank for a second and comes right back on. If i am playing a video while doing this, you can see it on the projection screen also.
I am going to play around with it somemore tomorrow starting with the hardware accelaration button, but wanted to see if anyone else might know what could cause it. I am trying to use a GeForce 5200X 256 mb video card with it.
Thanks!
Thanks!
geposted Sun 18 Sep 05 @ 11:08 am
Check this out, maybe you have same prob
https://virtualdj.com/forums/40194/Software_Technical_Support/Need_Serious_help.html?highlight=bogart
geposted Sun 18 Sep 05 @ 3:10 pm
thank you, I will have to check that out. I'll give an update when i have one.
geposted Sun 18 Sep 05 @ 3:29 pm
