Hello Everybody!
I have a problem with my first skin..maybe someone could help me..
I want to know wich element and property I have to set to configure the slider who show the song graph. I think there are 2 types (maybe more..) one flat and another one with more detail so you can see the cuts of the songs..
how I have to set to configure the detailed slider?
thanks!!!
thanks!!!
geposted Tue 20 Sep 05 @ 1:07 pm
Song graph is the "rhythm" element. If you want two different graphs to change between then use panel, then select wich panel to show with your slider.
Look at the documentation https://virtualdj.com/support/developers/skin.html
Also unzip a skin and look in the XML and see how others have done it.
geposted Tue 20 Sep 05 @ 1:22 pm
thanks...
I was looking for the "songpos" element. The attributes to set are:
volume
selected
volumeselected
hope this help someone
volume
selected
volumeselected
geposted Tue 20 Sep 05 @ 5:14 pm
