I just finished my new box and ran Aquamark3 on it and got 59,455. I burnt it in overnight and seems to be running great. I'm curious what everyone else getting with aquamark3? Post away.
geposted Tue 20 Sep 05 @ 5:29 pm
What are the specs of your system? What video card are you using?, you got almost 60k, it's great.
geposted Tue 20 Sep 05 @ 11:15 pm
I've seen athon64 systems get over 70 :)
geposted Tue 20 Sep 05 @ 11:49 pm
Share your specs! :)
geposted Sat 24 Sep 05 @ 8:28 pm
Intel D955XBK Board, (2) 512 Sticks of PC4200 533mhz, 3.0ghz P4 775 with 800mhzFSB 2mb, EVGA GeForce 6800GT 512Megs, WD Serial ATA Drive.
geposted Mon 26 Sep 05 @ 2:02 am
Interesting! :)
geposted Mon 26 Sep 05 @ 3:29 pm
Can you tell me where to buy the
17" TFT skärm
Thanks
17" TFT skärm
Thanks
geposted Tue 27 Sep 05 @ 6:55 am
You guys think your scores are good, try imagine what score ill get. specs below.... best guess gets a kiss :)
Windows XP Pro
Case: Antec Overture II, 550watt truepower PSU, modded with rear LED fan, blue cold cathode inside, highlights around mainboard rear inputs and outputs and front inputs. HDD cooler, front fan, rear fan.
Mainboard: Intel D945 PSNLK 775 PDual MB DDR2 PCIE GLAN HDAudio 8 USB2 SATA2 etc
CPU: socket 775 Pentium D 840 3.2ghz, 2mb cache(2 x 1mb), upto 1066fsb, EMT64T with thermaltake 775 silent cooler and using very very expensive thermal paste, runs silent and just under 35 degrees idle, about 40 42 when running things. Also supports PDual Execute Disable techonology.
RAM: 2 x 1gb geil ultra 667 DDR2 with red heatspreaders(dual channel, running really really fast ) :) :)
GFX: 256mb Nvidia 7800GTX(fuk i put it in yesterday u cant see on pics but yeah thats in there now, in pic shows a 6800gt)
HDD: 2x 74gb WD Raptor 10,000 RPM primary sata
Yes but who cares about the case? the case is what makes it look good and make it better :) and the LED's and CC make it run faster :)
The best part is songs load instantly, no wait. The only thing I wish that VDJ supported my CPU. The only problem is when i took these pics my technics 1210 mk5d's where getting serviced and they have BLUE leds to match :(
meh i got an external dvd-rw so i can just keep my case looking good without any drives making it look any less sexc.
No no thats not all guess what this is just my everyday PC hahahaha......... Don't ask whats in the rackmount case I take on DJ sets, though im purchasing VDJ, I was using final scratch but i discovered vdj so im using vdj once my order goes threw.
http://www.crazynerds.org/~kice/pics
Windows XP Pro
geposted Tue 27 Sep 05 @ 7:26 am
soz link i pasted was wrong its actually http://www.crazynerds.org/~kice/pc/
geposted Tue 27 Sep 05 @ 7:27 am
Kice, it's really cool. Congrats... I'm just a little dog with a Pentium 540. Not such specs, only down from EE 840. It's great.
And let me tell you VDJ support HT, I think a DualCore processor don't hurt at all. It's the logic device vs the real 2 processor device. For sure you notice a fast performance...
I wonder your Aqua Mark rate... Let me know it...
geposted Tue 27 Sep 05 @ 8:25 am
There is the 640 which has 2mb cache that makes you down two. Supports HT, though my processor doesnt have HT, its just a dual core which means it has a core for each thread unlike single core with HT has one core but supports two treads if I amke any sence
geposted Tue 27 Sep 05 @ 8:43 am
As DJ Cyder said "hes seen some amd systems get over 70"..... well might is well over, Id like to keep it a suprise as if someone gets a close guess I will tell you. Thats an AMD system, this is a hardcore penitum system
geposted Tue 27 Sep 05 @ 8:46 am
michaela_liebisch: English forum. 17" skärm (17 inch TFT monitor) can be found on various computer stores. Try some web based such as www.datorbutiken.com or www.komplett.se if a swedish computer store is what you are looking for. Use the Nordic Forum to ask questions in your native language.
geposted Tue 27 Sep 05 @ 12:45 pm
@DJKice
You gotta be talking well over 80....
Sweet spec machine btw!
geposted Tue 27 Sep 05 @ 1:35 pm
@Maleko
Good guess, 86 922
Good guess, 86 922
geposted Wed 28 Sep 05 @ 6:12 pm
