hey can someone post a pic of their system....setup...specifically one with a maya 44usb setup...i've seen the ones on the site....but maybe if i see a users set up i'll see something i'm not doing.
also i get 0% time code quslity but am able to hear the song at times granted some of the scratching is off and if u scratch too much the song starts going in reverse...this i feel is a time code issue though...i've muted the inputs in monitor channels 1-4 on the maya i still get nada. i've seen the tutorials etc and still cant get it
i use numark ttx tables that have a built in ground could this be the prob??
geposted Wed 21 Sep 05 @ 5:26 am
Maybe you have reversed the left and right channels; some adaptors have this problem, try changing the left and right and probe again. You must got more than 70% in Time Code quality. Try the Auto-Config option too (In the Advanced Config).
Check this for the Time-coded Vinyl Configuration: https://virtualdj.com/blog/acw_dj/image13.jpg
And this for the Maya Connections: https://virtualdj.com/blog/dams/image3.jpg
geposted Wed 21 Sep 05 @ 7:40 am
