Forum: VirtualDJ Skins
Topic: jpeg skins
is it so, that a jpeg-skin will run smoother because of the litle sice of it?
and another one.
how can i make a clipmask totaly black in a jpeg-skin? when i save it, the collors change a bit. so the clipmask won't work.
geposted Thu 22 Sep 05 @ 10:31 am
I don't think a jpeg skin will make VDJ work smoother. The program still have to use the image as a bitmap internal.
Yo john
Did you try with another editor?
FRUiT94
yes.....i tried..
Because of the way jpegs work, it's not all a solid color (which can be very annoying.) You will either have to use an advanced editor that can select a group of colors rather than just one, or fill in the color manually.
Another idea is to convert the jpeg to a low color depth bitmap (16 or 32 colors probably) and that should solidify it enough that you can work with it easily. Only problem with this is you're inevitably going to lose some of the quality.
yes, it's GREAT!!!!!! Best off All!!!!!!!!!
@igarok...you say anything else??? i'm just kidding but you said the same exact thing about a audio plug-in too....glad your finding things you like.
listen2: i think he's flooding ... hmmm or maybe he's drunk. LOL
Listen2, Lopez: Maybe He is just Happy!! ;-)
I think JPG take less resources to load and Manage.
