hey you pro's
i have the 3.1 virtualdj in english...
but it can't read some hebrew songs i have. it is really a disappointment for me.
can someone expirienced tell how can i install a hebrew jibrish fixer?
thanxxx
thanxxx
geposted Tue 27 Sep 05 @ 12:19 pm
the language file is a .XML file.. so rename it to LANGUAGE.XML (backup the current) located in \\VirtualDJ directory. should work. The language file can be downloaded here
https://virtualdj.com/addons/view.html?type=language
geposted Tue 27 Sep 05 @ 12:31 pm
thanx for the info but all of that i tried , doesn't work.
any sugesstions?
any sugesstions?
geposted Tue 27 Sep 05 @ 12:42 pm
i did what u told me, but i cant fined "\VirtualDJ directory" where is it?
geposted Tue 27 Sep 05 @ 2:45 pm
Uhm, new user??
The path where VirtualDJ was installed.. Check c:\\program\\VirtualDJ (default installation path). The language file is located there.. Search for the file is another option (start -> search)
It don't work if the files are named on hebrew language. Don't think they can "be translated". But there is a language file for names of functions in the program.
geposted Tue 27 Sep 05 @ 10:23 pm
