I can only select Front L/R in Asio settings!!!!!!
geposted Tue 27 Sep 05 @ 9:57 pm
Are you trying to use TCVs or TCCDs? what is the model of X-Fi you have?
geposted Wed 28 Sep 05 @ 6:17 am
No i will not use TCV i will use Headphones but i can only select front L/R!!!
My card is the model X-Fi ExtremMusic!!
Sorry for my bad english:)
geposted Wed 28 Sep 05 @ 1:38 pm
Please follow my instructions in my blog to get your headphones working, I think is what you need.
Viel Glueck!
(Good Luck!)
Viel Glueck!
(Good Luck!)
geposted Wed 28 Sep 05 @ 3:07 pm
Yes it works but not in asio mode:(
geposted Wed 28 Sep 05 @ 3:19 pm
Don't worry ASIO is for use with external devices like Turntables or CD-players. You don't need it to listen your headphones or VDJ alone.
geposted Wed 28 Sep 05 @ 3:27 pm
Ok thanks:)
geposted Wed 28 Sep 05 @ 3:35 pm
Sorry to dig this thread up, but I should mention something for people wanting to use the ASIO settings on their X-Fi. You must switch to "Audio Creation" Mode to get access to ALL your ASIO channels. You will only have Front L/R if you are in "Entertainment" or "Game" mode.
geposted Thu 02 Feb 06 @ 7:49 pm
HuGgLeZ,
Thanks for the input my friend. But if you are not going to use and external device (such TCVs or TCCDs) ASIO don't will be a big difference.
Thanks again Hugglez
geposted Fri 03 Feb 06 @ 12:19 pm
