Hi! Well my question is that.. Can me and my friend shoutcast at same time like b2b?
We have putted all thous shoutcast things up, but only one of us can play in radio. So do we have to download some plugins or what?
Thnx anyway! :)
Thnx anyway! :)
geposted Thu 29 Sep 05 @ 10:43 am
          do you mean a shoutcast tag-team??? you can check over at winamp but i would say 95% no.  A listener would have to have both of the links streaming at the same time, no player i know of will do that, its either one or the other.  You can get creative if you have multiple soundcards and have your friend stream to you, take that sound output into a channel(1) on a mixer, you will play on the other channel(2), the main output from the mix would go to a 2nd pc that would broadcast both sounds.....making your shoutcast link the only one a listener would select, your friend is using you broadcast them....lol i'm not even sure if that would work, that's on some mad scientist stuff but it might be done somehow like that..
    geposted Thu 29 Sep 05 @ 2:39 pm
