I am using a Numark cdn-88. I can only get one side at a time to get %100.
Any Ideas.
Any Ideas.
geposted Fri 30 Sep 05 @ 6:56 am
What sound card are you using?
geposted Fri 30 Sep 05 @ 7:05 am
Please you must check your RCA connections..and your soundcard configuration/compatibility
Regards,
Wyworg
Regards,
Wyworg
geposted Fri 30 Sep 05 @ 10:55 am
I am using a Myaa 44 usb.
geposted Fri 30 Sep 05 @ 3:36 pm
Thanks it was the cables..........If you dont see all green lights on the MYAA 44 then it is the cables.
One thing uou must know.
I have %100 on both side and my cdn-88 works well with skin
geposted Fri 30 Sep 05 @ 6:39 pm
It happends my friend... I'm Glad you get your setup working. ENJOY!
geposted Fri 30 Sep 05 @ 7:25 pm
