how do i put the numark skin on i have just loaded the trial version of virtual dj 3.1
geposted Fri 30 Sep 05 @ 10:41 pm
You have to put the skins in ZIP format in the Skins directory where is VirtualDJ installed. For example; the default path is C:\Program Files\VirtualDJ\Skins
The Numark skin is for 1280x1024. Your Screen must be with this or a greater value. VDJ has a preview skin to let you see if is what you want.
Enjoy!
Enjoy!
geposted Fri 30 Sep 05 @ 10:55 pm
had the same problem but that doesent work on my computer. Now my computer crashes all the time!! need help pls!!!!
geposted Mon 10 Oct 05 @ 8:14 pm
Some Skin works only with an specific version of VDJ. What skin are trying to use and what version of VDJ you have?
geposted Mon 10 Oct 05 @ 8:38 pm
