Topic: TCV's with trial version
Is it possible to use tcv's with the trial version? I ordered 2 of the tcv's from virtualdj.com so i could test the program before spending all the money on buying it. is it possible to use them with the trial version? I know i can only have 1 input because its a trial but....
i am not able to test how they control a cd.
thanks
ken
geposted Sun 02 Oct 05 @ 6:24 am
Have you tried Timecoded CD's? In theory you should be able to try 1 timecoded unit, if you have a proper sound card with ASIO support. There are some recommended mentioned before.
Timecoded mp3 is free > https://virtualdj.com/products/timecode/ is FREE. Burn as audio cd. Good luck
i dont want time coded cd's i want to see how this program works with vinyl, to see if its worth buying.
how do i know if my soundcard has asio support?
check the specs of your sound card to see if supports asio. Are you Greek?(if yes jump in the greek forum...because ksourounis sounds like greek..)
