For that the plugin lame_enc.dll is required.
You can download the required files here
geposted Tue 01 Jul 03 @ 5:37 pm
hye there yan-x...how are ya......just went to that site to download the dll file and is not in english...i don`t have a clue on what to do.....any ideas?......thanks
geposted Thu 03 Jul 03 @ 10:33 am
it is printed on the top os the page in english :
LAME ENCODER allows you to record your mix directly in MP3 format.
Unzip the file in your Virtual DJ directory.
Then launch Virtual DJ, go to the record tab, click on "Record in" to select MP3 format,
and click on "Plugin" to select the lame_enc.dll plugin
geposted Thu 03 Jul 03 @ 11:03 am
Hello Team!
I need to explain something...
Example:
I Cue the song at the first beat..ok? :)
The Cue point is cool, but if i STOP the song is not rewind on CUE 0 !!! (at the first beat)
The song is stopped at the beginning... :(
why?
In AtomixMP3 if i stop the song.... the song is rewind at the first CUE....
Please correct this bug!
and please i need an answer !!!
thx so much and best regards ;)
Paul
Example:
why?
Paul
geposted Fri 08 Aug 03 @ 8:25 pm
It is not a bug, but a difference with AtomixMP3.
Just click: Go to Cue #
geposted Fri 08 Aug 03 @ 8:58 pm
Thank you very much!
Peroz
Peroz
geposted Fri 15 Aug 03 @ 4:44 pm
click on stop once to go to cue 1
click on stop twice to go to the begining of the song
right click on stop to go to the first beat
geposted Fri 15 Aug 03 @ 5:10 pm
i want the cue to stay at the selected cue until i change it is that possible, i used the program in the field and found that troublesome, when tring to cue up to the next song. and can the loop also stay set until i change it?
geposted Wed 17 Sep 03 @ 5:20 am
Like Raw-Bear I went to the site to dnld lame dll. Only thing I saw in ENglish was New, Products, Playlist. Clicking on these only gives something else in another language. Any other suggestions on how to ge tthe lame dll necessary?
geposted Thu 08 Jan 04 @ 2:28 pm
To record in Mp3 the plugin lame_enc.dll is required.
You can download the required file here
There you should press over the buttom called "telecharger". And then you should click over the buttom called: Je suis d´accord
bye
bye
geposted Thu 08 Jan 04 @ 2:52 pm
Okay i followed instructions for the lame DLL. Now I can't get the prgm to load. I get a msg "Virtual trial exe encountered a problem and need to close" I deleted the DLL and still can't get it to load.
geposted Sat 10 Jan 04 @ 4:02 pm
Bogart
Contact http://www.virtualdj.com/support/e-service/
geposted Sat 10 Jan 04 @ 6:55 pm
HELLO TEAM
HAVE A NICE NEW YEAR !!!
I've tryed to record my mixing directly to MP3, like a plugin is needed i visited the page http://atomixfr.atomixmp3.com/lame.php, but it is not available to be use, probably there is some problem.
Could you please tell me where could I find the required plugin.
TKS
Bye, Bye !!!!
TKS
Bye, Bye !!!!
geposted Sat 01 Jan 05 @ 11:54 am
Sorry your level is not high enough to download this add-on. HOW CAN I DOWLN LOAD ALL THE AD ON \
AND HOW CAN I UPGRATE THIS LEVEL ?
geposted Sat 01 Jan 05 @ 2:08 pm
DJ Wizzard for more plugins upgrade from the mixstation version to the full vdj version
geposted Sat 01 Jan 05 @ 6:34 pm
both links to the lame_enc.dll plugin seem to be invalid. is there any other way to get it?
geposted Thu 24 Mar 05 @ 12:16 am
geposted Thu 24 Mar 05 @ 8:26 am
