Hi 2 all..
I can't run video plug-ins in the program.. When I open a video window, it shows me just black window.. :(
Who can I solve this one? (Maybe I'm doing something wrong?)..
Best Regards..
Best Regards..
geposted Wed 12 Oct 05 @ 5:11 pm
uncheck "hardware acceleration" and select a pulgin to view. It must work this way.
geposted Wed 12 Oct 05 @ 6:23 pm
Still not working.. :( Just a black screen when I pressing the "Open" button..
geposted Thu 13 Oct 05 @ 5:01 pm
I'm gueesing the 'open' button is actually the 'activate' checkbox.
With some of the plugins, you will not see anything until there is some sound on the main output.
Also, try using a window for the output and see if you get the same results.
Do you see videos or karaoke OK?
geposted Thu 13 Oct 05 @ 5:25 pm
What do you mean "mean output"? I'm loading the song on Deck 1 (4 example) and pressing play and "open" 2 activate the video window.. Still black.. :(
geposted Sat 15 Oct 05 @ 3:12 pm
Tiger,
Play a song in VDJ ok? then do this things: go to Config->Video->Show Visual Plugin select a plugin there for example SurealPotencial.svp and ACTIVATE the Video Output checkbox...
That works?
That works?
geposted Sat 15 Oct 05 @ 4:54 pm
I understand now.. :) But I have a little problem: NO Visual Plug-ins in the list.. ???
Where should they be? Or maybe I have a problem with my prog?
Best Regards 2 all..
Tiger.
geposted Sun 16 Oct 05 @ 10:26 pm
You can download from here: https://virtualdj.com/addons/download.html?addon_id=1091
Download and save in your PC as "VideoEffects.zip" (erease .html extension). Unzip them and copy to VitualDJ\\VideoEffects Folder.
geposted Mon 17 Oct 05 @ 4:07 pm
