| Autor |
- Topic: Chop and Screw - |
Posted Wed 12 Oct 05 @ 11:01 pm
How do I take the pitch down on the voice so that I can chop and screw a song anyone no let me no please |
Posted Fri 14 Oct 05 @ 9:42 am
I am a c/s dj get at me on aim trevdavis221 or go to www.myspace.com/djtrevdavis to hear some samples.
I can help you out if you use virtual dj. |
Posted Fri 06 Jan 06 @ 7:58 pm
i am also a c/s dj, and i made some c/s's songs it was very difficult i set Q on my keyboard to nudge-250, and i set my effect to flippin doubles to get that turntable chop effect and i held down the nugde and every so often i would do the flippin doubles is there a way to lock the nudge? and a better wat to "chop" it? because not always does the flippin doubles work(although it is a great effect), i can send u some of my c/s if you want, but any suggestions?
Posted Fri 06 Jan 06 @ 8:01 pm
also Dj Trev greattt chopped and screwedd songss reaall tuff :) |
Posted Sun 08 Jan 06 @ 7:10 am
Wat do u use?
atomixmp3?
Posted Thu 12 Jan 06 @ 1:14 am
im from souther houston where screw originated (rip)
just turn time strecth off pitch down till it feels good and offset either turntable by 1 beat or half a beat forward or back
-gauge |
Posted Sun 15 Jan 06 @ 2:09 am
thx it really helped :)...also i found another way to "chop" it you can use flippin doubles and change the BPM to about 60-70 to slow it down and it'll chop it nicely just like a turntable, but dont set it too low or it will sound too slow like this-----this is----is chop--------chop and---and screwed------screwed, the 60-60 BPM is almost accurate like cho-chopped. |
