when i play songs in the vdj it skip me all time what i have to do
i have computer t40 1.3 mhz centrino and win xp sp 2
and one sound card teratec phase 24 it connceted in firewire
some peole said that it because of the latency of the sound card so i just want to know why it happens and how i can fix this thanks
maybee i have to change something
wait for your answers
geposted Thu 13 Oct 05 @ 4:06 pm
Roy,
Check if you have a network interface that is not connected to any network. I know I have had similar problems with the Xircom network PcCard, and have heard of others with similar issues with other brands. The solution in these cases is either to remove the hardware, or the driver, or just connect that card to a network so that it is not periodically looking for a connection.
geposted Thu 13 Oct 05 @ 4:49 pm
DJRoy1,
Check this: https://virtualdj.com/forums/41333/Software_Technical_Support/reactivity_and_wave_speed.html
You can also try this: Change to "Desktop or Office use" the Energy Options in your Windows Control Panel instead of "Portable" (or other than Desktop or Office energy profile). Your laptop is going to perform better with this option for sure.
Good Luck!
Good Luck!
geposted Thu 13 Oct 05 @ 8:30 pm
with a 1.3 MHz processor hes gonna be having some problems lol
geposted Thu 27 Oct 05 @ 9:20 am
1.3 MHz should be fine for standard use.
geposted Thu 27 Oct 05 @ 4:16 pm
Lol Steve, My atari 800 had 1,79 Mhz CPU, when I was making music & demos in the old 8-bit times, lol
but it's true - i was enough for my standart use. ;-)
geposted Thu 27 Oct 05 @ 4:40 pm
LOL I honestly did n't notice that until after i had looked at it ......but if it is a 1.2Mhz and it runs VDJ with only skipping, i'll host a party at my house and they can spin. :)
geposted Thu 27 Oct 05 @ 8:14 pm
