when i open the config_pannel in vdj and go to video, i only see my video_plugins on the middle_left.
when i want to select one from below there nothing shown..
is this right??
is this right??
geposted Sat 15 Oct 05 @ 8:26 am
What's your VDJ version? in 3.1 you have more options...
geposted Sat 15 Oct 05 @ 5:14 pm
Have you verify it is the good folder on your hard disk, i mean all your video plugins are in "VideoEffects"?
geposted Sat 15 Oct 05 @ 10:53 pm
i use 3.1 and all my video-plugins are in video-effects...
i made a picca of it ...it's in my blog.
geposted Sun 16 Oct 05 @ 6:15 am
Download the effects and unzip them,
https://virtualdj.com/addons/download.html?addon_id=1091
then put files in the "VirtualDJ\Effects" folder AND THATS ALL...
Good Luck!
Good Luck!
geposted Sun 16 Oct 05 @ 11:21 am
thnx acw dj.
that was just what i needed.. i think i lost it with the fresh vdj instal.
thnx thnx and again thnx...
geposted Mon 17 Oct 05 @ 6:45 am
I might recommend that you take the time to see which ones eat up a lot of processing power... and be aware that if your system isn't top of the line, some will hit 75% or higher especially when responsive to lots of bass in the track.
geposted Mon 17 Oct 05 @ 7:15 am
I 2nd that. Some effects requires more juice than other...
geposted Mon 17 Oct 05 @ 7:22 am
If you find various ones that tax your system, you can remove them individually... I make a folder in the folder called DO NOT USE and put them in there for later when my system gets better.
geposted Mon 17 Oct 05 @ 7:33 am
Unzip what, acw? The file is named "sonique", with no extension. I added the "zip" extension, but when I tried to "unzip" I got an error message. What is the file's extension?
geposted Mon 28 Nov 05 @ 9:08 am
try exe maybe it's self installer now
geposted Mon 28 Nov 05 @ 11:33 am
Now is an EXE file. You only have to run it to uncompress all the files in it.
geposted Tue 29 Nov 05 @ 3:57 pm
