I have all the upgrades for VDJ. The problem that I'm having now is that once I close the program and I try to open it for the socond time, it won't open. It acts like it's going to open and instead it drops down to the task bar like it's open but nothing comes on the screen. I have to re-install the program in order to open it again. Once I close it and try to re-open it, the same thing happens again. What's going on? What's the solution to this problem? Thanks.
geposted Sun 16 Oct 05 @ 2:30 am
Are you using the default skin?
geposted Sun 16 Oct 05 @ 3:10 am
Try closing your anit-virus programs that are in the background.
geposted Mon 17 Oct 05 @ 2:49 pm
It's a problem of skins: you use a skin which isn't compatible with your screen and so vdj can't show the skins
geposted Mon 17 Oct 05 @ 9:35 pm
Open my computer/programfiles/virtualdj/skins and delete anything that isn't 1024X768 except the default skin, I trust your system supports 1024X768.
This will force the program back to the default skin.
Make sure your skins are all 3.1 compatable and of the right resolution, start from scratch if you aren't sure.
geposted Mon 17 Oct 05 @ 9:48 pm
A tip to show back the skin: rigth click with the mouse on the VDJ instance in the task bar (same line as the windows "start") open and select "move" and try to move the skin
geposted Tue 18 Oct 05 @ 12:28 pm
