Is there a way to export your Database to an HTML file to create a song listing? example winamp has an export to HTML.
Automixing a play list... is there a way to just have it play all the songs back to back and not automix/beatmatch them?
geposted Mon 17 Oct 05 @ 7:29 pm
          sure there is, use the text file and import it into excel, you may have to delimit it according to what you want.
2. Turn force fade on, Turn auto bpm off, Set fade time to 0.
geposted Mon 17 Oct 05 @ 8:35 pm
          #1 thanks I was trying to parse the XML file LOL, didn't even notice the text...
#2 SWEET, I turned off Force Fade because when I want to mix it takes over and I don't like that, but the Automatic mixin in the playlist covers the mixing part of it...
geposted Mon 17 Oct 05 @ 10:19 pm
          ...Why my database.txt file is always empty? It's 0 Kb!
I always backup the .xml file, 'cause I never seen my txt file to be filled with something.. (that's probably why VDJ updater 1.3 doesn't work as expected for me). What's wrong? Any suggestion?
Ciao!! :)
Ciao!! :)
geposted Tue 18 Oct 05 @ 11:16 am
          Arjuna,
The files in VirtualDJ 3.1 are "VirtualDJ Database.xml" and "mp3database.txt". All the information is in VirtualDJ Database.xml, in mp3databse.txt are the current path to the songs only.
geposted Tue 18 Oct 05 @ 6:20 pm
    geposted Wed 19 Oct 05 @ 1:25 pm
          Anytime fellow, I'm glad to help you ;-)
    geposted Wed 19 Oct 05 @ 3:13 pm
