Hopefully someone will know how to fix this.. I use a bunch of MP3's which the pitch slider at different spots and then the next time I load the Mp3 it seems to remember where the pitch slider was he last time and puts it there. is there any way to have it NOT do this? IE have it back at 0? I have the auto-pitch reset on but its not doing anything.
Thanks...
Thanks...
geposted Tue 18 Oct 05 @ 4:25 am
Turn off auto bpm, and enable force fade. You can find those settings in the config, fame settings.
geposted Tue 18 Oct 05 @ 6:42 am
Works sometimes and not other times.
geposted Sun 23 Oct 05 @ 4:58 pm
pitch reset puts pitch back to 0 when you change tracks but it will go streight to mathc the other song after it has been analysed (or instantly if it allready has) if you have auto BPM mathicng turned on. experiment with the options and find out what they do or alternativly read the instructions! they have them on the website somewhere
geposted Mon 24 Oct 05 @ 1:16 am
