I have my 2 time coded vynils on order and i was wondering if i could just use 2 soundcards instead of droppin over 100 dollars on a maya 44 or some other expensive usb or firwire soundcard? Will using my 2 soundblaster cards cause alot of latency?
Any one got an answer 4 me?
geposted Wed 19 Oct 05 @ 2:23 am
Actually you will need
A) The full version of VDJ to get both TTs to work with TCVs (In the demo only 1 TCV will work to give an example of how it works)
B) You can only use 1 soundcard to control TCVs unfortunatelly.
I would recommend the Maya 44 USB since most of us are using it and its quite stable. However the problem with the Maya is the fact that its discontinued :(
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Wed 19 Oct 05 @ 5:01 am
You could use ASIO4ALL for these two SB, but you may need the full version to get that working without troubles... And If you experience to much latency is because you don't use a proper ASIO sound card. I use them and are like real vinyls for me.
geposted Wed 19 Oct 05 @ 5:45 am
thanx
geposted Thu 20 Oct 05 @ 12:07 am
