Hello everybody...
When you drag the mouse on the stop recording-button (first you click start recordning, and after that the button is changed to stop rec.) the description of the button is "Start recording"... change it... (it not so difficult..?)
I don't think it's a bug, but maybe it is called a bug too...
geposted Thu 20 Oct 05 @ 2:41 pm
some other buttons need hint messages too
you're also not able to translate them all.
geposted Thu 20 Oct 05 @ 5:20 pm
In fact this sentence is in the language.xml in tooltips
geposted Thu 20 Oct 05 @ 10:45 pm
I don't see this parameter under tooltips in my language.xml file... What the name of it?
geposted Sat 22 Oct 05 @ 3:08 am
It's the field "record". Write "Start/Stop recording" if you prefer as there is only one function in VDJ for both.
Tips: in Tooltips section of language.xml, you can modify the tooltip or add new ones not written. Personnaly i added master tempo, timecode, bypass and auto_scratch. The fields are the VDJ function name ;-)
geposted Sat 22 Oct 05 @ 12:54 pm
Really thanks for the trick, now I wanna to modify the language.xml for my skin, but I think the standard language file is necesary to have some modify:
Use 'Fade' transition
Use 'Window' transition
Use 'Satellite' transition
Use 'Cube' transition
In the versione 3.2 and 3.3 it's possible to select different transition for the buttons 1-2-3-4
geposted Tue 31 Jan 06 @ 2:07 pm
