does anybody know if you could hook up your cd players to use them as tccd's since its got two sound cards??????
geposted Fri 21 Oct 05 @ 11:00 am
if you hook tccd to this mixer you have to switch the appropriate mixer channel to the line in where the cd is plugged. This way you can "record" with this soundcard to pc = have TCCD signal pass to pc.
But you are not able to listen the output of vdj, because the channel in mixer must be switched to LINE and not to USB audio output from VDJ.
I'm working on a mod for Numark DXM01 USB to be able to record something else than is playing thru the mixer channel. Since the signals from USB soundcards are handled internally analog it's
also possible to "rewire" your mixer too.
You will also need to use ASIO4ALL in order to combine those 2 soundcards into one virtual ASIO
geposted Fri 21 Oct 05 @ 12:35 pm
You can not use the Numark USB mixer as your TCCD soundcard. You still need something like a maya44 for doing TCCD. The nice thing about the Numark USB mixer though, is you can use the USB outputs to record your mixes, while removing one of the Analog/Digital conversions.
geposted Fri 21 Oct 05 @ 10:18 pm
You can use the Numark CM-200USB but it has to be modify to let you use inputs Line1 and 2 of your Mixer (for TCVs or TCCDs) and USB outputs Line 3 and 4 (From the soundcard of VDJ ~ USB Soundcard of CM200USB) and also the ASIO4ALL drivers as Lopez describe.
geposted Sat 22 Oct 05 @ 12:10 am
