I found this company very easy to locate the correct ram for my Sony.
The also were 1/2 the price of normal retail.
http://www.kahlon.com/
Before you order and upgrade, be sure you look at the current config.
You may have 512mb now but not have an open slot as manufacturers use 2 256 sticks.
This will mean 2 new 512 sticks are necessary to bring it to a full gig of ram.
geposted Fri 21 Oct 05 @ 12:47 pm
Another site that is verry helpfull for finding memory, even for oddball systems and self built PCs is crucial www.crucial.com. They have a database of almost every manufacturer and Motherboard manufacturer. Their memory is also to notch high quality stuff.
geposted Fri 21 Oct 05 @ 7:43 pm
I would highly recommend crucial.com. I personally have bought thousands of dollars of ram from them and never had one go bad, not fit or anything like that.
geposted Fri 21 Oct 05 @ 10:15 pm
