Hello!
I`m from Germany and my English is not so good.
`ve got aproblem with this dll.
Where must i send it to?
And how can i activate it?
Please help me!!!!
Please help me!!!!
geposted Fri 21 Oct 05 @ 1:07 pm
put it in the c:/program files/VirtualDJ/effects folder
probably you will have Mixstation3 or something other and not Virtualdj as the name. Then you can select between browser, effects, samples. Select effects and on the left side take effect and drop it on the effect slot with the mouse.
I'm not sure becuase I'm using virtualDJ but ....
geposted Fri 21 Oct 05 @ 2:20 pm
I think this plugin is only for VirtualDJ.
geposted Fri 21 Oct 05 @ 5:05 pm
No the minimum level for this plugin is "home edition user" but maybe it's better to set it to "professional edition user"
What do you think lopez453?
geposted Fri 21 Oct 05 @ 6:23 pm
AtomixMP3 is also consider a Home User. Maybe in this case it should work
geposted Fri 21 Oct 05 @ 6:33 pm
Just now i tested the demo of atomix, none of my plugins work with it ...
even if it could help atomix users having separate outputs and connect it to mixer and makes sence to give it to them, it's not working so please promote all my plugins to PRO users only,
They won't get confused ...
I'm sorry :-(
I'm sorry :-(
geposted Tue 25 Oct 05 @ 7:13 pm
