Hello, im using virtual dj for home use, recreational and for partys sometimes ...
But now i have a problem, if i want to record a mix it isn't possible .. it's says can't open mp3 encoder. ..
What can i do, or what do you suggest to do ...?!
With kind regards ..
AK
AK
geposted Sun 23 Oct 05 @ 6:27 pm
What version are you using?
MS
MS
geposted Sun 23 Oct 05 @ 7:19 pm
sounds like the lame codec isnt found. if you look in options or something you can find where it is being looked for. it should be a .dll file i think.alot of wares dont remember to include anciliary files like this as they only care about the actual program but if you downlaod another you can probably take the dll file out of that and put it into the rite folder in your current install saving you seting it up again and looking up all your database etc.
geposted Mon 24 Oct 05 @ 1:04 am
Im using version 3.0 ....
Ill try what u said Dj Xeo ...
Thanks
Thanks
geposted Wed 26 Oct 05 @ 11:03 pm
ive gotta ask. how do you know
geposted Thu 27 Oct 05 @ 9:03 am
