hi, my qustion: is there a possibity to connect final scratch with virtual dj? ?? =:-)
geposted Wed 26 Oct 05 @ 11:22 pm
You mean the hardware? You can only use the Soundcard from Final scratch (I'm not really sure of this)... but you can't use the TCV for sure, you must use the TCVs from VirtualDJ.
geposted Thu 27 Oct 05 @ 12:02 am
i searched but i cuoldnt find tcv, i use verwsion 1.9, do i need a higher version?
geposted Thu 27 Oct 05 @ 12:40 am
i checked version 3.1, and i was not able to activate it, i didnt fount tcv, i ovly found d vinil 2020, where should i look ?
geposted Thu 27 Oct 05 @ 12:53 am
You need a higher version, from 2.05 is the option available. I recommend you to upgrade your current version to VDJ 3.1... Did you have a Hercules DJConsole?
geposted Thu 27 Oct 05 @ 4:23 am
in later versions it's not under "remote controls" but you have to choose the last option
on the tab "soundcard selection" - asio timecoded ....
geposted Thu 27 Oct 05 @ 10:32 am
geposted Sun 30 Oct 05 @ 1:29 pm
geposted Sun 30 Oct 05 @ 1:30 pm
Did anyone ever try using the final scratch hardware for a TCV setup, i might be able to get one real cheap and would be a simlpe USB soundcard solution.
geposted Tue 01 Nov 05 @ 6:07 pm
noone has found a way of using ether scratch amp in decent asio mode. have a look on the djdecks forum for people trying and failing
geposted Wed 02 Nov 05 @ 2:41 am
I have Final Scratch 2 Amp. Will give it a go sometime.
geposted Wed 07 Dec 05 @ 4:55 pm
