I played a gig using the below equipment;
AMD Athlon 2500XP+
1 GIG RAM
2 x 120Gb HD
Audigy 2 Soundblaster card
External Mixer
Mp3's encoded at 192kb/sec minimum using Razorlame.
I use the front and rear channels for left and right speakers on the sound card. When playing the tracks I can hear the volume dipping slightly and then returning to normal level... hard to explain....it's not mega-noticeable but I can tell it's not perfect! I think I've got all the right settings checked...thought it could be something to do with the gain????? maybe I've missed something. Can anyone help me out. I love the program, I just want it working correct on my setup. Cheers.
AMD Athlon 2500XP+
1 GIG RAM
2 x 120Gb HD
External Mixer
geposted Wed 07 Apr 04 @ 7:39 pm
try disabling the limiter.
geposted Wed 07 Apr 04 @ 9:08 pm
If you don't wanna disable the limiter just make sure the gain never goes over 0db and you will not here the dips.
geposted Thu 08 Apr 04 @ 7:08 am
Thanks a lot!
I'll try these.
What are the disadvantages of disabling the limiter?
Do I disable the gain in order not to let it go above 0.0?
Thanks again
I'll try these.
Thanks again
geposted Thu 08 Apr 04 @ 5:13 pm
No need to disable the auto gain. Just set the gain of the first track you load for the evening to -1 or so, and the rest of them will load at -1.
Personally I shut off the limiter, and set the gain to 0.0
But, that's just me.
geposted Thu 08 Apr 04 @ 5:51 pm
Excellent........!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Cheers for your help!
Software's superb!!
Software's superb!!
geposted Thu 08 Apr 04 @ 6:12 pm
