hi i just purchased vdj and i can only use the skin size 800x600, all the other skins dont fit on my screen please advise thnx.
jrmc.
jrmc.
geposted Thu 27 Oct 05 @ 6:36 am
you can change your resolution.
geposted Thu 27 Oct 05 @ 8:07 am
maximising a skin will attempt to change your screen to that resolution. if it doesnt fit chances are the display will not go bigger than 800 600
geposted Thu 27 Oct 05 @ 9:06 am
