On VDJ at the top under the automix it has the sound bar which you can use to match beat correct ?? Im new to this stuff! Anyway how on earth do you slow it down my eyes wont keep up ?
geposted Fri 28 Oct 05 @ 1:05 pm
To slow down/speed up the music, use the PITCH sliders. For help regarding beat mixing technique, read the thread at 'Mix lessons' > https://virtualdj.com/forums/6288/Mix_lessons/DJ_MIXING___basic_-_advanced_-_pro.html
geposted Fri 28 Oct 05 @ 3:55 pm
On the other hand, if your eyes can't follow the waveform on the screen, it means you have zoomed in too much so try too zoom out and you will see the waveform will scroll not so fast anymore.
geposted Fri 28 Oct 05 @ 8:28 pm
