hi i have a P4 2.8 ghz dell machine with 512 ram the recommended ram mentioned by VDJ is 1gig are many people using VDJ with 512 ram and if so are you finding things are stable? any crashes if not running at 1gig ram?
cheers
cheers
geposted Mon 31 Oct 05 @ 7:07 pm
The problem is when you use video... you may need more RAM to handle properly.
geposted Mon 31 Oct 05 @ 10:04 pm
not going to be using video just mixing and using effects, loops, etc etc so whatcha think?
geposted Tue 01 Nov 05 @ 3:54 pm
sorry that anon message came from me would be grateful if anyone can shed some light on the subject cheers
geposted Tue 01 Nov 05 @ 6:16 pm
You will be fine as long as you fine tune your Windows install. Eliminate unnecessary processes, etc.
geposted Tue 01 Nov 05 @ 6:46 pm
thanks for responses but not being a tech head could someone send any links for step by step instructions to optimising windows for such an application?
would i also need to re - install windows for optimisation or could i tweak the current install?
thanks
thanks
geposted Wed 02 Nov 05 @ 2:47 pm
