Hey Guys,
I just recorded a mix, and instead of getting an mp3 at the end I ended up with a .bin file - I must have clicked the wrong button.
Anyway I need to get this on mp3 - can anyone tell me the best way to do this?
Thanks
Thanks
geposted Tue 01 Nov 05 @ 12:01 am
Hi colinfitz
As far as I know you just rename the file as filename.mp3 as opposed to filename.bin
That should help you out...unless one of the other guys can think of another way?
Cheers, and keep spinnin'...:o)
P
P
geposted Tue 01 Nov 05 @ 12:07 am
I think Pionara is right, if you rename your file from .BIN to a .MP3 this will work.
Cheers!
geposted Tue 01 Nov 05 @ 3:09 am
Hmm, tried that and it did not work. Any ideas?
geposted Tue 01 Nov 05 @ 7:15 pm
burn the BIN file in NERO, if you dont have it try goldenhawks CDRWIN , the demo will burn it but only at 1x
geposted Tue 01 Nov 05 @ 9:02 pm
Would it work wiht CDburnerXP Pro?
http://www.cdburnerxp.se/help/english/convertiso
At the bottom it says:
Note: If you convert an audio-CD image to ISO it won't work because ISO images do not support audio images.
Is this the case for the VDJ .bin file?
geposted Tue 01 Nov 05 @ 11:58 pm
an ISO is similar to a BIN but not the same types, just download CDRWIN the demo works forever(i think) just burns only at 1x
geposted Wed 02 Nov 05 @ 1:30 am
