Ok, I moved my music files from a local partition (E:) to an external (G:), now the database shows double entries for every song. How can I remove all the former E: drive entries from the database?
    geposted Thu 03 Nov 05 @ 3:05 am
          DiamondDoug,
Only right-click in VirtualDj ->Search Database-> ERASE CD select E. Done. I there are songs that may no t be availabel in search database, use the ERASE option on each Letter and then do the same but now with ADD to Search Database.
Good Luck!
Good Luck!
geposted Thu 03 Nov 05 @ 3:27 am
          SWEET, worked like a charm. Thanx for the help!
    geposted Thu 03 Nov 05 @ 3:40 am
          Glad I can help you ;-)
keep it spinning...
    keep it spinning...
geposted Thu 03 Nov 05 @ 3:57 am
          there is also a usefull lil proggie called vdj database cleaner.. that works well too..
    geposted Sat 05 Nov 05 @ 10:20 am
