I JUST DOWNLOADED ASIO4ALL AND ARE TRYING TO SET IT UP BUT HAVE NO IDEA WHAT TO DO WHEN IT COMES TO AUDIO CONFIGURATION. IF ANYONE CAN HELP?
geposted Fri 04 Nov 05 @ 3:22 am
Here is a great link for you to check out...
https://virtualdj.com/support/VirtualDJ%203%20-%20Advanced%20ASIO%20configuration.pdf
MS
MS
geposted Fri 04 Nov 05 @ 3:58 am
Hey thanks for the link but for some reason it didn't work. think you could resend it. thanks.
geposted Fri 04 Nov 05 @ 5:00 am
It's a .pdf file.
Do you have Acrobat reader installed ?
Adobe.com
Adobe.com
geposted Fri 04 Nov 05 @ 5:59 am
yeah, let me try again
geposted Fri 04 Nov 05 @ 6:12 am
Got it. Thanks a bunch
geposted Fri 04 Nov 05 @ 6:36 am
