I've been unable to get headphones to work with VDJ 3.1 and my SB Audigy 2 [FECO] laptop PCMCIA sound card. Not sure if it's something I'm doing wrong or if the card just can't do it.
Can anyone give me a suggestion? If it means using some kind of hardware add-on (Hercules?), I'm open to doing that. Not being able to separately hear what's cued up is just not good.
Thanks for any help you can offer.
Howard
Howard
geposted Fri 04 Nov 05 @ 4:21 am
HowardShap,
Look in my blog, I have the answer in there, title: "Headphones on one Soundcard".
geposted Fri 04 Nov 05 @ 5:31 pm
acw, thanks for your reply. I had already checked your blog previously and for whatever reason have had no success getting it to work. I get confused with the 4.1, 5.1, etc.....I have no idea what configuration to set it at. It's an SB Audigy 2 [FECO].
I'm all but ready to try the Hercules add-on if that will allow me to use the headphones. Can you or anyone tell me if that will allow me to use headphones regardless of the soundcard?
Thanks for your much appreciated help,
Howard
Howard
geposted Sun 06 Nov 05 @ 3:02 am
