Forum: VirtualDJ Skins
Topic: THIS SKIN IS NOT WORKING Cdj200s
did you check this skin because it's not working,when i try to open it says this skin is invalid
geposted Fri 04 Nov 05 @ 5:40 am
I have tested it and it works with vdj v3.1
Be careful, when you download it, you now get an .exe file and not a .zip file
Install the .exe like a program
still can't this skin to work i did all what you said still nothing
Are you using the 3.1, or another else one? ƒяμﺄτ
Skin works great!
download with EXPLORER not FIREFOX.
My Skin no work,Please Help.
Hi,
i like this skin so much and has video console on it.
Does anyone knows how can i contact Paky g? I'd like if he can develop the skin for 1200x800 wide screen resolution and make some Font changes...(smaller)
Thanks
Kike
Maybe see his blog otherwise he will maybe read you...
ƒяμﺄτ
He is not registered user so I think he has no blog....
Right... Last method : maybe try to open one of his skins, then edit the xml part and see at the header of the file maybe he left his mail here...
ƒяμﺄτ
No way to contact PAKYG...
...anyone knows how to adapt the skin to 1280 x 800 without loosing high definition?
...any quick advanced skinner class volunteer??? :)))
I have his mail but i don't know if i can share it
Hi, i'm here!
Hi,
I'm using your skin at my club for two weeks. It's great for video mixing but I'd like to ask you if you are able to make a version for 1280x800 screen and fonts a little bit smaller in order to display more titles at playlist area.
Congratulations for your skin
Kike
I vote for a 1280*800 too.
Hello,
i'm having probems with VDJ 3.2 and i don't know if it's the skin. Is anybody using CDJ200S with 3.2?
This is my skin of choice at the moment. Looks and functions really well.
