Couple of play list questions..
1. Is there a way to use the p;lay list function to play the entire song but then switch to the next song without hearing ay dead space which is at the end of the Mp3 WIHTOUT setting cue points? I tried setting the Fade time to .2 but it seemed to still cut off the end of the song and the corss fade was very quick.
2. what does CROSS FADER "smooth" "full" and "CUT" mean. I assume CUT means to just cut to the next song but whats the difference between FULL AND SMOOTH?
3. I've also see someone set up the play list so it will play all the songs in the list but it will beat match and then slowly return the pitch to "0" so the song plays at the normal speed.. how was this done?
geposted Sat 05 Nov 05 @ 10:14 pm
