I have buy a mixer a bit time ago and I want to register my mix with its..
If use record function of virtual dj, register all music and prelisten... What can I do I want to register only music exit from my speakers not from headphone..
I have tested with x-ripper but the quality is horrible and the software it's too old.. thanks
geposted Fri 09 Apr 04 @ 12:57 pm
Hi,
Which mixer do you use with VDJ ?
Do you have a reccord output into your mixer ?
Regards, Laurent
Regards, Laurent
geposted Fri 09 Apr 04 @ 2:05 pm
Hi I have a Omnitronic Pro 524... Yes I have a output for record and I have a soundblaster audigy 2 on my PC..
thanks for reply
thanks for reply
geposted Fri 09 Apr 04 @ 2:13 pm
Great !
You juste need to link the reccord output of your mixer to the reccord input of your sound card and use the Creative stream reccorder or something like that.
Good luck, Laurent
Good luck, Laurent
geposted Fri 09 Apr 04 @ 2:33 pm
Ok thanks.. What the best program for record? thanks..
geposted Fri 09 Apr 04 @ 2:40 pm
I use the Audio strean recorder which in the USB External Soundblaster Audigy 2 NX package.
Laurent
Laurent
geposted Fri 09 Apr 04 @ 7:37 pm
