How do i set up virtual dj to run through seperate channels on my mixer? i do not see the option to do so like it is on atomixmp3
    geposted Tue 08 Nov 05 @ 1:05 am
          either have 2 soundcards or you need a Y adapter and split the signal, then take the outputs from the cards/y split and plug them in channel 1 and 2 of the mixer
    geposted Tue 08 Nov 05 @ 3:21 am
          there is an option, take a better look at the icons...
    geposted Tue 08 Nov 05 @ 3:24 am
          make sure you select the right setup in soundconfigurations inside Virtual DJ
Look very closely at the easy-to-use pictures, that will show what setup you are looking for...
Either 2 x soundcard, or 4.1/5.1 soundcard or stereo splitter.... pluss external mixer
all possible, just select the one that fits you, depending on your hardware setup
geposted Tue 08 Nov 05 @ 4:20 am
