Is anyone using the U46DJ Soundcard with TCV's. I'd like to know if it works perfectly cause i'm considering getting it instead of the Maya44. Any feedback will be greatly appreciated.
geposted Tue 08 Nov 05 @ 3:17 pm
Mantahoe,
Why don't search in the forum until you do a question?
The U46DJ don't work in native ASIO mode with VirtualDJ. You have to use ASIO4ALL with it. And if that is going to happend, is the same as you have two soundcards with cost you less than the U46DJ solution.
If you are going to use TCVs is better if you BUY VirtualDJ, the cracked version of VDJ always have issues and problems that will not let you work properly. Also, you are not going to have any support here if that happend, or the recomendations will not work with your version.
You can try the Demo, you can buy the product, but if you use the cracked version we can't help you with the problems you may have with it.
Help us, use the version we known.
geposted Tue 08 Nov 05 @ 5:30 pm
