EVERYTIME I TRY YO RUN VIRTUAL DJ I GET A PROTECTION ERROR 16 OR PROTECTION ERROR 19 WHAT IS THAT ABOUT ??
geposted Mon 12 Apr 04 @ 3:29 pm
Please contact the e-service
https://virtualdj.com/support/e-service/
geposted Mon 12 Apr 04 @ 3:34 pm
For help on this problem you must submit your problem to the e-service.
Has anyone gotten past this problem. I have been sending these messages to technical support all day and have not gotten anywhere. I am sure there are others who are quite frustrated in having to wait for solutions that DO NOT WORK. Does anyone have a solution that WORKS for the DJ Mixstation 2?
geposted Thu 22 Jul 04 @ 11:16 pm
Did you contact them on the website, or did you use the email address? If you used the email address, it will not work. You have to go through the website:
macourteau
macourteau
geposted Thu 22 Jul 04 @ 11:25 pm
I did everything thru the Technical support website. I am on this forum out of frustration after having wasted too much time trying to install something that should be straightforward.
geposted Thu 22 Jul 04 @ 11:29 pm
Only the e-service can help you with protection errors; there is nothing the users can do about it (and they are very efficient at fixing these problems usually).
macourteau
macourteau
geposted Fri 23 Jul 04 @ 12:19 am
jsammers
Your problem comes from the cracked version you have installed before...You can't find an answer for your problem here.
Thanks
Thanks
geposted Fri 23 Jul 04 @ 4:28 am
