Forum: Wishes and new features
Topic: White Curser
Any chance we might be able to have a pointer option?
It seems that with the black skins the cursor is easy to loose.
It is controlled by the program and nothing on the windows side will alter it which I find odd.
We should have the choice I think.
I am sure others that use Pioneer skins will agree.
Rick
geposted Mon 12 Apr 04 @ 9:20 pm
Yep I agree, the cursor has the same color as the skin's background. An option to use the windows cursors would be great.
FRUiT94
yup.
An option would be cool
another thing with the 'mouse' could be to have an option that controls the speed of the mouse cause it goes slower in VDJ than in windows.. wich is kinda annoying. It should either be the same as windows or an option.. you do the pick :)
