Has anyone found a way around this ?
I want to use TCV and Normal Vinyl, TCV works fine when it is plugged into the inputs on the soundcard of the maya44usb, Normal Vinyl also works fine into the mixer.
I have just got some Y-Cables so I can split the output from the TT's to the phono inputs of the mixer and to the inputs on the MAYA44usb. TCV still works perfectly well and i get a 100% signal, However when playing normal vinyl there is a very noticable loss of quality, probably due to splitting the low-level phono signal.
I was thinking of getting a couple of phono pre-amps and splitting the line level output instead (going into the secondary line level inputs of the mixer and into the maya, hopefully splitting this signal will not have as much of a noticeable effect on quality. Or a switch box i guess.
Any ideas ? Has anyone done anything similar ? Or maybe I need to configure the lead setup differently?
geposted Thu 17 Nov 05 @ 1:09 pm
well... all good things come from Dams ;)
https://virtualdj.com/blog/Dams/blog738.html
geposted Thu 17 Nov 05 @ 1:18 pm
Nice picture... but the configuration is exactly what i've already got, As I say, it does infact work, there is just a noticable quality loss on normal vinyl :( - Due to splitting the signal I believe.
geposted Thu 17 Nov 05 @ 1:29 pm
mabey you have bad quality splitters because im pretty sure that the quality should not be affected. try auditioning the setup with a normal vinyl playing and see if the quality changes when you unplug the split to the sound card and put it back in again.
geposted Fri 18 Nov 05 @ 6:40 am
geposted Sat 19 Nov 05 @ 8:21 am
Don't think its the leads - although I did solder them up myself - The signal on normal vinyl is fine until you plug the cable into the soundcard, suggesting its not the leads.
geposted Tue 22 Nov 05 @ 1:07 pm
i had exactly the same problem, so i bought two switch boxes. you plug record deck in input and there is a switch you can select between two outputs. one output to the sound card and one output to the mixer.
they cost me five pounds each, but cant remember what web site from.
geposted Tue 22 Nov 05 @ 11:49 pm
Yeah I thought of doing that :), Shame though as already have switch on the mixer to alternate the channels between VDJ output and Vinyl - would have to switch two switches each time for each channel - 4 switches in total.
Can you remember the make (and maybe model) of the switch boxes and i will google it...
geposted Wed 23 Nov 05 @ 12:45 pm
Can you help me?
When i have the turntable connected near my notebook to use virtualdj and i put on my turntable a Normal Vinyl no timecoded vinyl, can i hear the sound?
There are problems?
There are problems?
geposted Thu 24 Nov 05 @ 10:03 am
You can get the Hercules console mk2 + the full version of VDJ, and you will have an easy accessable bypass mode for real vinyl :)
Low priced VDJ offfer at internet now :
https://virtualdj.com/purchase/
Hercules console is here:
http://www.hercules.com
geposted Thu 24 Nov 05 @ 10:12 am
