Hi all,
I would like to know if it is possible to index the mp3 files in virtualdj or anybody know a good one software else.
When i try to find an artist in the search bar it can't find in the sub directories is there a way to do that ?
Thx
Thx
geposted Thu 17 Nov 05 @ 7:32 pm
Tacticman,
the search in vdj is very good. Before you are able to search you need to let VDJ search for your mpr3 files. This is the way you could do this:
- Open vdj
- In the browse list, right click on database and select "Scan HD" Select your hard disks and click "OK"
After the search is finished you are able to search for all data stated in the name of the file. So if you file is "Artist - Title.mp3", you could search for (a part of) the title or the artist.
Ewout
- Open vdj
Ewout
geposted Thu 17 Nov 05 @ 8:18 pm
many thanks for your reply i didn't know how to do it but it seems to be very good as you said.**
thx
thx
geposted Fri 18 Nov 05 @ 10:42 pm
you're welcome,
glad you liked the search as well.
Ewout
Ewout
geposted Sat 19 Nov 05 @ 8:06 pm
