How about a button so that different video transitions can be used randomly? Sometimes it's a pain to manually shange them.
geposted Fri 18 Nov 05 @ 6:36 am
the command to change the transition is mappable so you can create a skin button to do it or a keyboard shortcut. or assign it to the rotary encoder near your crossfader on your x-session MIDI controller....................
geposted Fri 18 Nov 05 @ 6:57 am
"rotary encoder near crossfader on x-session" that's what I did and it works great. Don't even need to have the corresponding buttons on the skin, because there are only 4 possible posistions and you can easily turn the knob to where you are sure its position is unambiguous. Even just put labels around the rotary knob.
geposted Mon 21 Nov 05 @ 11:41 pm
Who did you think i was talking about? lol........................
geposted Tue 22 Nov 05 @ 1:05 am
